chgofrank
#1 Posted : Thursday, August 25, 2011 11:44:08 AM(UTC)
chgofrank
I disassembled my Thermador range to replace capacitors that are causing the oven control display to go dim and finally to go out almost completely. While doing this a wire slipped out of the J1 connector. I am not sure which slot it goes back into. I believe it is pin #1, 2, or 3. Judging from wear on the pins of the connector it looks like it goes to pin #3. However, I would like to confirm this with a wiring diagram or a picture. Can anyone find a diagram for this unit? It uses a Robertshaw Controls unit. When I called Robertshaw they said they did not have the diagram since it is an OEM part. Thermador is hopeless.
magician59
#2 Posted : Thursday, August 25, 2011 11:55:18 AM(UTC)
magician59
Just click on the link created by your model number and follow the prompts to the diagrams page. scroll down through the diagrams until you find the wiring diagram that will help you the best.
chgofrank
#3 Posted : Thursday, August 25, 2011 3:11:50 PM(UTC)
chgofrank
Thank you for directing me to the wiring diagram for my model. One big problem is that it is of such poor resolution that I cannot read it. I can't make out any lettering or identify the connector that I am concerned about. Is there a higher resolution diagram available -- either on the web or hard copy?
magician59
#4 Posted : Thursday, August 25, 2011 6:41:04 PM(UTC)
magician59
Here's a website that archives service manuals. Registration is free. No guarantees, but you may find what you're looking for there.
ApplianceDigest.com - Appliance Repair Service Manuals
wiring diagram for oven control (Oven Repair (including Ranges and Cooktops))
by dlcasey 11/24/2008 11:11:06 AM(UTC)
