on heavier loads water is pumped out but load not spun dry.remove some load and use drain /spin option and load spins dry but seems nosier in doing so. with load not sufficiently lightned , sounds as though it is trying to spin but no spin .the loads that do not spin dry are of a size routinely handled by this machine in the past.
Rank: Administration
Groups: Administrators
Its possible there is something caught between the tub or the clutch is worn. I f you remove the cabinet you can carefully run it. Check the clutch drum is to see if its after you have run it in spin. You may also notice the noise coming from it.
