I have an old (50 years) Meyer forced air furnace that keeps shutting off. The issue is that my outside air conditioner is running and building up cold air inside the exchanger since the furnace does not kick on for the blower to circulate the air. A simple flip of the switch on the side of the furnace restarts the furnace and it will work for a couple of days and then do it again. Any ideas?
Originally Posted by: eldon_brasche ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) I have an old (50 years) Meyer forced air furnace that keeps shutting off. The issue is that my outside air conditioner is running and building up cold air inside the exchanger since the furnace does not kick on for the blower to circulate the air. A simple flip of the switch on the side of the furnace restarts the furnace and it will work for a couple of days and then do it again. Any ideas? Check the switch on the thermostat. Sounds like it ma be bad.
