AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Water pools around bottom of front loading washer
Good Afternoon All,
I actually did buy an extended warranty on both my front loading washer and dryer, and I did remember to schedule maintenance 2 out of the three years, and I had to have one service call. I recently turned down an offer to extend the warranty ... still not upset over that one...however?
Issue: Water has been pooling around the bottom of the unit...incrementally. The problem does not appear to be associated with the door/tub gasket. I am thinking that it is hose related. I see that there are several related to this machine: Pump, water intake, water outtake, etc...has anyone else had this experience, and if so, is it something that I can repair myself without great expense? Any help here will be greatly appreciated. Of course, I can always call Sears back to see if they will extend the warranty...they said that this was still a possibility. Thank you!
Warranty Avoider
Are you using He soap? If not, Thats your problem!!! If you are, use less soap!!!
Washer Repair
