My lid switch is broken. The water is stuck inside. the washer will not spin because of the lid switch. How can I install it my self. Is there photos I can refer.
there are two screws on your plastic end caps in back . take them out. then pull forward and flip up. then you will see 2 clips under this panel you fliped up about 3 to 4 inches from the sides. take screwdrive and put in the front part of clip and snap out. unplug wire connector and pull whole cabinet back toward you. by the way make sure you unplug washer before you start.
