renewer
#1 Posted : 14 years ago
renewer
Hello,
My dishwasher won't drain completely. I can see water coming through the drain tube to the disposal but it doesn't seem to be able to drain fast enough before the pump stops. I've cleaned the tub out of all food I can see but I'm not sure where else I can check for clogs. Thanks for any help.
Ryan
renewer
#2 Posted : 14 years ago
renewer
Fixed the problem, there is a filter in the back of the tub that has a grated cap over it. I emptied the tub of water, removed the filter cap and cleaned it, cleaned out the tub under the cap and put it all back together. It's working now.
f1fan
#3 Posted : 14 years ago
f1fan
I found out that a toothpick got wedged in one of the 2 pumps underneath the dishwasher not allowing it to remove any water. I took about 15 minutes to remove the pumps and find the toothpick in the smaller of the two. If I can take them apart anybody can. I found this service paper underneath the dishwasher that had diagnostic information on how to test the pumps. Sure enough, one worked and one didn't. I hope this helps somebody else.
GE dishwasher won't drain after last rinse cycle (Dishwasher Repair)
by autotech1 7 years ago
GE Dishwasher won't drain all way (Dishwasher Repair)
by AnthonyJS02 10 years ago
GE Dishwasher won't drain (Dishwasher Repair)
by crabbygardener 11 years ago
by mistercoffee1 11 years ago
GE dishwasher won't drain (Dishwasher Repair)
by Junebugatl 12 years ago
by Annie G 12 years ago
by brianlevenstein 12 years ago
by ann123 12 years ago
GE dishwasher won't drain completely (Dishwasher Repair)
by knight9995 12 years ago
by thuybrad 13 years ago
GE Dishwasher Won't Drain (Washer Repair)
by Jennifer216 13 years ago
GE Dishwasher Won't Drain Completely (Dishwasher Repair)
by ldubrowski 13 years ago
Belarus deaconden 13 years ago
GE dishwasher won't drain, not plugged up (Dishwasher Repair)
by BonnieF 13 years ago
by Bart1110 14 years ago
