bigbluetrk17
#1 Posted : Wednesday, March 25, 2009 8:48:34 AM(UTC)
bigbluetrk17
I NEED A front glass for the upper door of a gemini range the model #is mer6771aaw.the part #is 13 series-74005577 and the serial#is 17542470zm. Itis a white door. Can;t find anywhere.Isthere something that I can interchange with another brand. thanks
bigbluetrk17
#2 Posted : Wednesday, March 25, 2009 8:51:40 AM(UTC)
bigbluetrk17
I need a glass for the upper door of a double oven.Model#mer6771aaw and serial#17542470zm
Adam / APP Team
#3 Posted : Wednesday, March 25, 2009 9:49:03 AM(UTC)
Adam / APP Team
Rank: Administration
Groups: Administrators
bigbluetrk17,
Unfortunatly the manufacturer has discontinued it and made no replacement. Since everything is researched by model numbers and not by size all you can do is keep checking around to see if anyone would have one left in stock or see if you can find a glass company that can make it to the size needed.
#4 Posted : Thursday, March 26, 2009 3:06:51 AM(UTC)
Measure the size of glass required and the window size/location. A diagram may help. Also the thickness.
Then make the rounds to appliance stores, if you cannot obtain a glass, you may be doing this anyway.
Perhaps you will get lucky and find a unit with the same size glass and a window which is close to yours.
The glass is tempered so getting one made will be difficult and you cannot use standard glass.
Did notice that the window has a foil heat shield, you could use the metal tape that is used for sealing heating ducts for this.
Frank Barry (Dryer Repair)
by Frank Barry 4/5/2016 9:35:25 AM(UTC)
Franklin Chef refrig/freezer stopped working (Refrigerator & Freezer Repair)
by Baseball Dad 6/25/2012 11:15:01 AM(UTC)
franklin000 (Microwave Repair)
by franklin000 6/5/2012 6:53:08 PM(UTC)
frank (Oven Repair (including Ranges and Cooktops))
by angie1754 9/30/2010 10:45:23 AM(UTC)
Frank (Oven Repair (including Ranges and Cooktops))
by angie1754 9/29/2010 12:35:19 PM(UTC)
by FBRTKO 11/11/2009 3:02:23 PM(UTC)
jerfrank (Dryer Repair)
by jerfrank 6/26/2009 8:49:31 AM(UTC)
frank (Refrigerator & Freezer Repair)
by frose 2/24/2008 6:14:15 PM(UTC)
Frank (Washer Repair)
by fvas 8/29/2007 9:01:01 AM(UTC)
