Originally Posted by: richappy ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) If you have a burnout, or the compressor has sucked in air, you must replace the filter/dryer. Last one I did, it was a simple bad compressor, no contamination, so I never changed it. I understand most dryers have a micro screen that prevents particles from entering the cap tube, but in your case, maybe it is missing. Thanks. I am going to change the filter and work on the cap tube. I'll let you know how it works out.
What's the big secret or is it that none of the internet professionals know the answer?
Here are the correct pressures from Frigidare Service Data Sheet #218758400 and these pressures work for most residential systems using R134a refrigerant @ 65*F Ambiant .
Low Side Pressure: Cut-in = 6 to 13 Cut-out = -2 to +2
High Side Pressure: 105 - 115 Wattage: 150 - 220 Amps (Running): 1.3 - 1.8
