2 Pages<12
wysened
#11 Posted : Friday, August 5, 2011 3:54:07 AM(UTC)
wysened
Originally Posted by: richappy Go to Quoted Post
If you have a burnout, or the compressor has sucked in air, you must replace the filter/dryer. Last one I did, it was a simple bad compressor, no contamination, so I never changed it.
I understand most dryers have a micro screen that prevents particles from entering the cap tube, but in your case, maybe it is missing.
Thanks. I am going to change the filter and work on the cap tube. I'll let you know how it works out.
DeepThought
#12 Posted : Sunday, September 29, 2013 5:07:36 PM(UTC)
DeepThought
What's the big secret or is it that none of the internet professionals know the answer?
Here are the correct pressures from Frigidare Service Data Sheet #218758400 and these pressures work for most residential systems using R134a refrigerant @ 65*F Ambiant .
Low Side Pressure:
Cut-in = 6 to 13
Cut-out = -2 to +2
High Side Pressure: 105 - 115
Wattage: 150 - 220
Amps (Running): 1.3 - 1.8
Marat
#13 Posted : Thursday, January 23, 2014 10:16:38 AM(UTC)
Marat
2 Pages<12
