trash compactor ram is stuck in compacted (down) position and motor still runs. unplugged and will not reset. can stop motor with top off and using the stop limit controller manually. help?
Originally Posted by: jlarkins  ...can stop motor with top off and using the stop limit controller manually... Can you describe it more detailed please? Gene.
opened the bottom panel and found out the gear drive is cracked in half. assumed that's the problem.
You got it! You can save almost $40 on the part using the drive gear kit made by Whirlpool. This trash compactor designed by Whirlpool and GE resell Whirlpool made parts. - The drive gear kit Part number: AP3122987
Originally Posted by: jlarkins  trash compactor ram is stuck in compacted (down) position and motor still runs. unplugged and will not reset. can stop motor with top off and using the stop limit controller manually. help? I have the same problem. How do you get the ram back up???
Originally Posted by: J.Noble  I have the same problem. How do you get the ram back up??? Can't get unit out of wall to repair?
