My washer in the middle of a cycle just turns off and keeps door locked. Not sure what to look for. Please help
Inside the lower service panel or under the top should be tech notes that will tell you how to put it into a diagnostic mode. Also, you should be able to reach in from the lower part of the machine after the lower service panel is off to get to a tab which you can pull to manually unlock the door if you need to.
