the oven took 45 minutes to heat to 250 i can hear a switch-relay clicking on-off. i am attempting to findout part# before i tear the top off the stove:confused:
Everything is controlled by the oven control board ( AP2127094), but if it is slow to preheat, you may want to verify voltage to both elements and check them both for proper resistance and that there is no visible damage. I would suspect our bake element is not working and the preheating being done is only through the cycling of the broil element.
