Like others in this forum, I'm attempting to repair a dryer (in a GE Spacemaker Laundry Combo), where the end of the Idler/Tension Arm spring has actually broken, resulting in the inability of the arm to maintain tension against the belt. I've ordered a new spring (and a new drive/drum belt), but my question is, where exactly does the end of the spring mount to the dryer body? I can see a hole where the spring loops through the Idler/Tension arm, but the only place I see for the other end of the spring, to attach to the dryer body, is a small hole, almost directly under the spring end, that is drilled into the sheet metal between the upper and lower sections of the unit. I suppose that you could kind of tilt the end of the spring into this hole, but that results in the spring sitting off-kilter at the bottom, and could lead to the spring-end slipping out of the hole. It seems to me, that there should be some sort of bracket where the spring-end could loop through something on the bottom end of it as well. OR, maybe instead of just 1 hole, two small holes, drilled side-by-side, would be more appropriate (as this would enable the curve of the spring-end to loop around something?) Any help in this endeavor would be VERY grateful ... Thanx in advance ... Jeff Clements
Any help with this problem would be very, very appreciated... Thanks.. JeffC.
