msladyh
#1 Posted : Thursday, July 14, 2011 7:41:08 AM(UTC)
msladyh
The other night we smelled something "hot" (possibly electrical) around the dishwasher so we stopped it & were going to look into next day. Well the next day daughter goes to start it (not knowing all of this happened) and the LED lights light up like it is going to start & then turns off. It will not run or drain. The LED lights light up when they are pressed, but nothing happens. Any suggestions would be GREATLY appreciated. PLEASE tell me it's not time for a new one!! :(
Joe / APP Team
#2 Posted : Thursday, July 14, 2011 8:39:27 AM(UTC)
Joe / APP Team
Msladyh,
Several things you should check, first.
Remoev the lower access panel, and kick plate, remove power to the dishwasher, remove the cover from the junction box cover, and check the wiring and wiring nuts for damage, loose, burn marks.
From there we need to suspect a problem in the door switches or wiring, or the control panel keypads.
HIGH TEMP WASH ⇒ HEATED DRY ⇒ HIGH TEMP WASH ⇒ HEATED DRY
If the above key sequence is entered with the dishwasher in Standby, the
Diagnostics Cycle is started. The Diagnostics Cycle can be rapid-advanced,
interval by interval, by pressing the Start/Resume key.
If you cannot program the diagnostic cycle, suspect the keypad / control panel assembly is at fault.
Good Luck,
msladyh
#3 Posted: : Thursday, July 14, 2011 10:04:23 AM(UTC)
msladyh
Joe,
Thank you so much for your prompt response. I don't know if we will be able to check tonight, but we will soon!!
Thanks agiain!!
Joe / APP Team
#4 Posted : Friday, July 15, 2011 5:10:39 AM(UTC)
Joe / APP Team
Joe,
Thanks agiain!!
Ladyh,
Not a problem, we understand, and will keep an eye out for your post.
msladyh
#5 Posted : Wednesday, July 27, 2011 6:32:33 AM(UTC)
msladyh
Not good news... When we went to check per instructions... The LCD lights no longer work! :0(. Now what?!
Joe / APP Team
#6 Posted : Wednesday, July 27, 2011 10:35:06 AM(UTC)
Joe / APP Team
Mslady,
So you did the basic reccomended checks, and the unit is dead, now.
You're going to need to get access to a multi meter
Part number: AP3873826
So we can check the thermal fuse circuits and voltage at the control board.
Part number: AP3115186
Part number: AP3961536
That way we can pin point the problem and get you up and going.
