millerbeachbum
#1 Posted : Friday, November 16, 2007 10:03:53 AM(UTC)
millerbeachbum
My 18 month old Frigidaire refrigerator ha stopped cooling. The unit is used in a vacation home has run less than 40 hours in 18 months.
The timer, fans, defrost circuit all test fine. The compressor runs and cools slightly but cannot lower the temperature in the freezer or fridge.
I noticed some rust on the welds that connect the compressor tubing to the coil that dissapates the heat from the compressor. Below the rusting welds (as if it dripped down) I notice a quarter sized area of white powder in two areas.
Is it possible that the refrigerant has leaked from these rusted areas? Is this why the fridge only cools slightly? Is this common?
Th only control I haven't tested is the thermostat...should I test that also?
Thanks!
abbie
#2 Posted : Friday, November 16, 2007 11:09:05 AM(UTC)
abbie
sounds like a low side leak in system ..[low on 134a gas]
#3 Posted : Friday, November 16, 2007 11:21:06 AM(UTC)
Remove the back cover in the freezer and inspect how the evaporator coil is covered with a snow. Normally it suppose to be 100% covered.
If it's much less then the cooling system is low on Freon and has to be serviced by a certified technician.
Brand New Refrigerator won't cool below 42 (Refrigerator & Freezer Repair)
by mariasamba 6/30/2018 1:48:34 PM(UTC)
Maytag refrigerator won't cool (Refrigerator & Freezer Repair)
by mimossi 4/25/2016 6:12:55 AM(UTC)
Frigidaire refrigerator won't cool (Refrigerator & Freezer Repair)
by pmandare 1/24/2015 9:08:02 PM(UTC)
Kenmore refrigerator won't cool. (Refrigerator & Freezer Repair)
by Tomjenks 12/4/2014 4:25:46 AM(UTC)
Refrigerator won't cool (Refrigerator & Freezer Repair)
by normskiboy 11/14/2011 1:01:31 PM(UTC)
GE Refrigerator won't cool (Refrigerator & Freezer Repair)
by DennyA 11/1/2011 9:42:23 PM(UTC)
kenmore side by side refrigerator won't cool (Refrigerator & Freezer Repair)
by possystems 9/5/2011 1:17:09 PM(UTC)
Refrigerator Won't Cool (Refrigerator & Freezer Repair)
by gonz6191 2/22/2011 8:26:33 AM(UTC)
freezer is fine refrigerator won't cool (Refrigerator & Freezer Repair)
by KerryH2010 6/8/2010 7:03:56 AM(UTC)
Refrigerator won't cool more than 50 degrees (Refrigerator & Freezer Repair)
by greenbizman 12/15/2009 12:12:38 PM(UTC)
by postmaster2 8/26/2009 11:46:23 AM(UTC)
Haier 2.7 Refrigerator won't cool (Refrigerator & Freezer Repair)
by Walleye cooter 8/17/2009 12:20:46 PM(UTC)
Refrigerator won't cool down (Refrigerator & Freezer Repair)
by tech 6/2/2008 3:05:52 PM(UTC)
GE Refrigerator won't cool or freeze top half (Refrigerator & Freezer Repair)
by embalmer 12/28/2007 11:39:07 AM(UTC)
