I have a Whirlpool model ED22TWXDW00 side-by-side refrigerator. The water dispenser stopped working years ago, but we did not really use it that much so it didn't matter then. Now, however, the dispenser outlet is leaking alot even though it is not used. The ice maker is working fine. Does this model have a water filter? If so. I cannot find it. If there is no filter, does the problem sound like its being caused by the inlet valve?
Originally Posted by: platemaster ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) I have a Whirlpool model ED22TWXDW00 side-by-side refrigerator. The water dispenser stopped working years ago, but we did not really use it that much so it didn't matter then. Now, however, the dispenser outlet is leaking alot even though it is not used. The ice maker is working fine. Does this model have a water filter? If so. I cannot find it. If there is no filter, does the problem sound like its being caused by the inlet valve? I have a KitchenAid refrig. Water dispenser in door does not work while ice maker works fine. Water filter replaced and re-checked and is okay. Any help would be greatly appreciated. Ric.
