dexgiroux
#1 Posted : Thursday, March 12, 2009 5:05:49 AM(UTC)
dexgiroux
Amana top-load cloths washer model no. ALW480DAW makes a clicking noise during the mid-range of the spin-dry/water-drain cycle. There appears to not be any excessive out-of-balance nor does the clicking sound occur during the first (slow) part of the spin cycle nor at the top-end (fast) part of the spin. The Helix functions properly and is not the source of the sound. It seems to be coming from either just above or below the transmission, possibly in the bearings. Could the roller bearing / one-way-clutch be the problem and if so, is there an easy way to replace it other then disassembling the whole washer as seems to be suggested in the service manual I found on-line at http://www.scribd.com/doc/8677902/Amana-Top-Load-Washer-Service-Manual?from_email_04_friend_send=1 ?
Also, is the roller bearing part of the transmission assembly ... do I need to buy the whole transmission to get that bearing?
Guest
#2 Posted : Monday, January 3, 2022 4:07:35 PM(UTC)
Guest
Groups:
My Amanda doing this clicking sound on spinning cycle. I did the diagnostic on it I did not took it apart or anything any suggestions?
Guest
#3 Posted : Monday, January 3, 2022 4:09:37 PM(UTC)
Guest
Groups:
My Amana washer making this clicking sound constantly on spinning cycle I did a diagnostic test on it. I did not take it apart or anything any suggestions?
