firedude
#1 Posted : Wednesday, July 6, 2011 4:47:50 PM(UTC)
firedude
kemore series 70 heavy duty: when in the delicate cycle it will fill and agitate but does not drain or spin. So for the other cycles are not affected. Is this possibly a timer problem, if so how do I test the timer for a specific cycle?
sidfink43
#2 Posted : Friday, July 8, 2011 3:48:55 PM(UTC)
sidfink43
It is very likely a timer problem. You can try disconnecting the timer and cleaning the contacts with a good contact cleaner, but in the end I think you will just have to replace the timer.
Guest
#3 Posted : Saturday, October 23, 2021 7:00:28 AM(UTC)
Guest
Groups:
My Kenmore heavy duty70 series washer starts spinning get almost up to speed makes a little grinding noise n then makes a loud bang and slows slightly then speeds back up n bangs again. If I hold the agitator still while it spins theirs no bang runs like normal. What might be going out or is wrong
Kenmore 70 series washer grinding (Washer Repair)
by Higginsdog 5/28/2024 4:17:38 AM(UTC)
Kenmore 70 series (11066712694) cycling thermostat wire damage (Dryer Repair)
by cyberdingo 3/6/2024 6:26:19 PM(UTC)
Sears Kenmore 70 Series . Model 110-82870120 (Washer Repair)
by washerTed 10/2/2023 6:42:28 AM(UTC)
Kenmore 70 series not starting after breaker tripping (Dryer Repair)
by thenameskilo 4/7/2021 10:25:38 PM(UTC)
Kenmore 70 series not starting (Dryer Repair)
by thenameskilo 4/7/2021 10:24:08 PM(UTC)
Kenmore 70 series gas dryer not heating (Dryer Repair)
by Gilmo211 12/29/2020 10:09:04 AM(UTC)
kenmore 70 series problem (Washer Repair)
by richham 6/13/2015 4:08:08 PM(UTC)
Kenmore 70 Series washer not spinning (Washer Repair)
by workingdad 2/21/2015 7:31:47 PM(UTC)
Kenmore 70 series washer doesn't work (Washer Repair)
by kman6206 1/17/2015 3:38:49 AM(UTC)
Kenmore 70 series (Washer Repair)
by D.mccauslin 1/7/2015 6:20:04 PM(UTC)
kenmore 70 series not spinning unless manually put to spin (Washer Repair)
by adm388 8/13/2014 8:58:14 PM(UTC)
Kenmore 70 Series Dryer Heating Element (Dryer Repair)
by VSimon10 3/6/2014 2:19:25 PM(UTC)
Kenmore 70 series agitates but no longer spins (Washer Repair)
by ken110 1/26/2014 5:19:15 AM(UTC)
Kenmore 70 series washer agitates but does not spin (Washer Repair)
by tismichael 11/16/2013 2:02:16 PM(UTC)
Kenmore 70 series washer won't drain or spin (Washer Repair)
by ImSR 10/12/2013 8:49:49 AM(UTC)
