bh1962m
#1 Posted : Wednesday, July 6, 2011 8:13:06 AM(UTC)
bh1962m
the Compressor Runs For About 5 Seconds And Then The Overload Kicks It Out. The Overload Was "very Hot". Does The Relay And Overload Need To Be Replaced?
bh1962m
#2 Posted : Wednesday, July 6, 2011 8:19:16 AM(UTC)
bh1962m
Originally Posted by: bh1962m Go to Quoted Post
The Compressor Runs For About 5 Seconds And Then The Overload Kicks It Out. The Overload Was "very Hot". Does The Relay And Overload Need To Be Replaced?
WHEN I SHOOK THE RELAY IT SOUNDED LIKE THERE WERE LOOSE PARTS IN IT. AND WHEN I TOOK THE RELAY OFF THE COMPRESSOR I MADE CONTINUITY CHECK I GOT A READING ON ALL THREE POST IS THAT NORMAL.
richappy
#3 Posted : Wednesday, July 6, 2011 8:23:54 AM(UTC)
richappy
You can try a new start device AP3083556. Make sure you either take a picture or mark down where each start device wire went.
