dgramfan
#1 Posted : Tuesday, March 10, 2009 5:54:01 PM(UTC)
dgramfan
No Ice Or Water FrOm Freezer Door Dispenser. Night Light Not Working ( It Has Been Replaced).
No Activation Of Ice Dispenser Motor.
Plenty Of Water To Ice Maker, Ice Maker Is Working.
I Feel That This Might Be A Power Supply Issue To The Door Dispenser Controls . What Do You Think?
HotBacon
#2 Posted : Tuesday, June 1, 2010 4:32:10 PM(UTC)
HotBacon
I just had this exact same issue. I found that the power wire that comes from under the unit, into the bottom corner of the freezer door, had corroded and came loose. I pulled the wire apart at the connector, stripped some insulation off the white wire, recrimped the tip on, and put it back into the connector. Once I attached the connectors, the power was supplied to the dispenser and all was well w/ the world again (for now).
