All of a sudden the water and ice is not working on the fridge. If we press any of the buttons (water, cubed, crushed), the display shuts off for a second. When the display comes back on, it shows a 0 (zero), then shows the temperature settings for the fridge & freezer.
Any ideas?
I figured out my own problem. I read that some people had issues with corroded wires going to the display. I took the grill off the bottom-front of the fridge, and on the left side of the freezer door is the wire which goes up to the display. One of the wires in the connector was corroded. I clipped off the connector and spliced the wires (using moisture resistant gel filled splice locks).
Everything works perfectly now. Saved myself plenty of cash on possible replacement parts and a service call.
