Degranola
#1 Posted : Friday, March 6, 2009 3:57:37 AM(UTC)
Degranola
I am having prblems with the microwave. 1st the latches stuck open, dummy me with out unplugging the unit, while taking the latch / switch off to reset I touch the side and blow a fuse???? replaced the fuse. Every thing came on and is working, but not heating items inside the mic.. The board functions all work? I replaced ALL (3) Switches (#AP3890699), Thermostat(#AP3038826) and the Capacitor(AP303617). All parts in the interior and ventilation area. Still no luck. Any one have any more info. Thanks
#2 Posted : Friday, March 6, 2009 7:30:02 PM(UTC)
Remove the wires from the high voltage transformer primary windings and check for 120 VAC between these wires while the control calls for heat and the door is closed. Be careful not to electrocute yourself.
If there is 120 VAC then the problem most likely is a bad magnetron.
If there is no 120 VAC then the control board probably is bad.
Here are the break down diagrams and the parts list for the Whirlpool microwave Model MH2155XPB1
Degranola
#3 Posted : Sunday, March 8, 2009 4:29:45 AM(UTC)
Degranola
Where is the magatron located on the MH2155XPB1? I didnt or dont see it int he diagram?
#4 Posted : Sunday, March 8, 2009 3:28:13 PM(UTC)
If you scroll down through the menu on the left side all the way to the bottom you'll see the diagram: "Magnetron and turntable parts". The magnetron is #14 on this diagram.
In order to access the magnetron you have to remove the microwave from the cabinet and remove the outer case.
Whirlpool Microwave Lower Bulb will not turn on (WMH31017HS08) (Microwave Repair)
by Axtell 1/2/2024 3:49:44 PM(UTC)
Replacing Handle on Whirlpool Microwave GH4184XSS1 (Microwave Repair)
by barbhickman13 8/28/2022 7:09:07 AM(UTC)
Whirlpool microwave LED (Microwave Repair)
by kafka45 3/20/2021 9:48:06 AM(UTC)
Whirlpool microwave/oven not working (Oven Repair (including Ranges and Cooktops))
by naik71 9/3/2020 5:51:16 PM(UTC)
Whirlpool microwave ovens countertop (Microwave Repair)
by boxershubhammm 9/23/2019 10:06:07 PM(UTC)
Whirlpool Microwave Door Sensor Part & Diagram? Need help (Microwave Repair)
by ellie0704 4/8/2019 8:26:28 AM(UTC)
Whirlpool Microwave Door Error and flipped breaker when plugged in (Microwave Repair)
by ellie0704 2/9/2019 9:12:28 AM(UTC)
Whirlpool Microwave stopped working (Microwave Repair)
by Myron S 12/19/2017 4:21:39 PM(UTC)
Whirlpool microwave open/close door (Microwave Repair)
by jigrami 3/6/2017 12:45:32 PM(UTC)
Whirlpool microwave door handle broke (Microwave Repair)
by troyw66 11/9/2016 6:32:52 AM(UTC)
Whirlpool microwave vent fan not working (Microwave Repair)
by mshaw8099 7/22/2015 2:07:41 PM(UTC)
whirlpool microwave code F1E4 mw power relay (Microwave Repair)
by sja527 12/21/2014 3:36:17 PM(UTC)
Whirlpool Microwave died... (Microwave Repair)
by michaellawre 7/4/2014 2:24:47 PM(UTC)
Whirlpool Microwave Started Smoking (Microwave Repair)
by mharnisch 1/15/2014 12:48:02 PM(UTC)
Whirlpool Microwave not heating (Microwave Repair)
by ddelay 10/15/2013 5:16:23 PM(UTC)
