tracib01
#1 Posted : Tuesday, June 14, 2011 1:32:15 PM(UTC)
tracib01
Views messages in topic : 1
We have read similar problems in your forum, but we still cannot figure out what the source of the problem is. At the end of the spin cycle it makes a loud clunking noise, but works fine otherwise. Obviously, the safety feature does not allow the lid to be open during spin cycles. Any suggestions?
#2 Posted : Tuesday, June 14, 2011 7:14:07 PM(UTC)
Open the lid and manually check if the inner tub is not loose.
Remove the front panel and check the belt, the idler pulley and the tension mechanism.
