My GE Advantium 120 started to make a noise like there was a motor spinning but there was no air movement from the vent. The vent hi/low works fine and the noise is still there when using the vent fan. I can make the noise go away when I use the warm/reheat button for a couple of seconds low power, either moist or crisp setting. When I cancel the cook time the noise stops for a few minutes. Maybe 10 minutes? Any suggestions? Thanks for your help.
