bberinger1
#1 Posted : Monday, February 23, 2009 9:35:51 AM(UTC)
bberinger1
Washer wont spin. Only makes hummunig noise. New transmission, clutch. Could it be the drum assembly?
#2 Posted : Tuesday, February 24, 2009 3:00:55 PM(UTC)
Rank:: Advanced Member
Remove the cabinet and check for a foreign object stuck between the inner and outer tubs.
Remove the motor and check it it would run on spin without a load. Post the results.
