Hergenroeder
#1 Posted : Wednesday, June 8, 2011 10:02:27 AM(UTC)
Hergenroeder
I am not sure of the date of purchase about 4 years ago and it is an actual Gold Star model.
and but :mad:My question is when I use it , set the time and start it works, then
will not work screen shows only L and beeps on and off. I have tried to unplug from main outlet, let it set overnight and it will work. but again only once and then the L appears again and it won't work.
Do you think the problem is on the panel? Thank you. marie t. pastir
Hergenroeder
#2 Posted : Wednesday, June 8, 2011 10:04:57 AM(UTC)
Hergenroeder
I am asking what to do about my microwave that shuts off after 1 use and the letter L appears on the panel, beeps on and off and stops working
Hergenroeder
#3 Posted : Wednesday, June 8, 2011 10:48:19 AM(UTC)
Hergenroeder
I have a Gold Star microware that has not stopping after one use and the letter L appears on the touch panel. Does this mean that the microware is not broken, or what kind of problem should I be looking for, I have unplugged it from the wall, turned off the circuit braker, left it sit overnight and sometimes it comes on works and then again stop with the letter L appearing in the time slot.
