kap43
#1 Posted : Sunday, February 22, 2009 1:34:56 PM(UTC)
kap43
Micro. quit heating , observed lite smoke comeing from connector on magnetron. Also put volt meter on connector comeing from transformer and read 3.2 volts a.c. is that rite. thanks
fellicianot1
#2 Posted : Sunday, February 22, 2009 1:54:05 PM(UTC)
fellicianot1
Is This Something Commun
kap43
#3 Posted : Sunday, February 22, 2009 4:57:13 PM(UTC)
kap43
i don't know , thats the problem i'm haveing
richappy
#4 Posted : Monday, February 23, 2009 3:35:58 AM(UTC)
richappy
Seems like your high voltage transformer is not getting any voltage. Usually they will hum if getting voltage. Also, meter readings may be very innacurate near this transformer if drawing current.
You should check for missing voltage from the pc board. Sometimes re soldering the connections to this relay will fix it.
kap43
#5 Posted : Monday, February 23, 2009 1:55:12 PM(UTC)
kap43
hi thanks. i nuplugged the connector from trans. going to the magnetron and turned the micro. on and took voltage reading at the conn. comeing from trans.
