MMiller 400
#1 Posted : Friday, February 20, 2009 12:50:36 PM(UTC)
MMiller 400
When trying to reheat food, close the door, timer counts down, light is on, but the maguetron does not engage so the food does not heat. This is an intermittent problem. Is this symtomatic of a lower door switch or can something else cause this?
With the door open I can only see 1 door switch on the lower latch. I have not had it apart yet, is there more than one switch I need to be concerned with?
TechnicianBrian
#2 Posted : Friday, February 20, 2009 3:15:43 PM(UTC)
TechnicianBrian
There are three interlock switches that all must be actuated for the microwave to operate. If this problem seems to come and go, it's often due to the door sagging or out of adjustment resulting in the door not contacting the switches. If you remove the grill and the screw that holds the control panel in place, you can see the interlock mount which is held to the frame with two screws. This mount can be moved a little if needed to provide for better contact.
Frigidaire Microwave PLMVZ169HCA (Microwave Repair)
by Guest 10/25/2023 11:02:01 AM(UTC)
Frigidaire Microwave exhaust keeps running after some parts have been replaced. (Microwave Repair)
by robbietpa 3/29/2021 11:27:01 AM(UTC)
Frigidaire microwave grease filter/ how to replace a grease filter (Microwave Repair)
by melissakiser 7/11/2019 11:15:00 AM(UTC)
Fan turns on when door open for frigidaire Microwave (Microwave Repair)
by rbsolanki 1/30/2016 5:04:49 AM(UTC)
Frigidaire microwave stopped heating (Microwave Repair)
by darrenwelson 3/24/2014 7:15:32 PM(UTC)
Frigidaire microwave heating intermittently (Microwave Repair)
by amowry 4/11/2013 11:38:14 AM(UTC)
Frigidaire Microwave (Microwave Repair)
by mumzyanna@netzero.com 3/12/2013 8:41:25 AM(UTC)
Frigidaire Microwave intermittent turntabke and light (Microwave Repair)
by autoclaveman 11/27/2012 6:52:45 AM(UTC)
Frigidaire Microwave stopped working (Microwave Repair)
by Grace11797 5/23/2012 3:32:22 PM(UTC)
by wshodges 11/3/2011 8:50:51 AM(UTC)
Frigidaire microwave display partially dark (Microwave Repair)
by blazerino 7/14/2011 2:07:04 PM(UTC)
Frigidaire Microwave Problem (Microwave Repair)
by qztfwq 5/18/2010 10:28:42 AM(UTC)
Frigidaire Microwave light and motor/fan turn on when the door closes (Microwave Repair)
by briceeking 3/15/2010 5:50:30 PM(UTC)
frigidaire microwave (Microwave Repair)
by klandau 2/19/2010 7:18:23 AM(UTC)
Frigidaire Microwave turntable won't turn (Microwave Repair)
by djo 9/12/2009 6:02:05 PM(UTC)
