terik
#1 Posted : Friday, November 9, 2007 6:51:03 AM(UTC)
terik
How do you get to the bolt to replace the roller assembly on the whirpool trash compactor?
Admin / APP Team
#2 Posted : Friday, November 9, 2007 3:54:31 PM(UTC)
Admin / APP Team
Rank: Administration
Whirlpool has a couple of different compactor designs. Post the model number.
terik
#3 Posted : Saturday, November 10, 2007 1:48:44 PM(UTC)
terik
How do you get to the bolt to change out the roller assembly on the whirlpool trashcompactor model # GX900QPP?
#4 Posted : Saturday, November 10, 2007 5:42:26 PM(UTC)
Hi terik
There are two different kind of rollers on this trash compactor.
The first pair of rollers (#16 on the container brake down diagram) are attached to the rear part of the drawer (aka container).
The second pair of the rollers (#9 on the frame break down diagram) are attached to the body of the trash compactor, in the front.
In order to replace any of them you have to completely remove the drawer from the trash compactor. Also, to replace the front rollers you have to pull the trash compactor out of the cabinet for about 8" to get access to the nuts.
Good luck.
teodozia pepe
#5 Posted : Wednesday, February 25, 2009 7:58:40 AM(UTC)
teodozia pepe
Hello Terik: What I did on my masher is pull it out in the open. Remove the back cover (which on mine is the full height. this will allow you to remove the top cover which should expose the inner workings.
John Wieczorek
#6 Posted : Wednesday, November 11, 2009 6:21:55 PM(UTC)
John Wieczorek
Hi! Our compactor has locked up. The compactor came with the house, dated possibly late 1980's. Basic one switch that reads lock, on, off. Model number is in the door which will not open. Any suggestions. Ann
#7 Posted : Thursday, November 12, 2009 1:14:30 PM(UTC)
cheryl zim
#8 Posted : Thursday, November 12, 2009 2:47:00 PM(UTC)
cheryl zim
Our trash compactor "ram" is locked down, the door popped partially out, the controls will not work now. How can we correct this?:eek:
#9 Posted : Thursday, November 12, 2009 5:02:07 PM(UTC)
Remove the unit from the cabinet and post a pictures of the unit.
Whirlpool trash compactor model TU800SPKB0 (Trash Compactor Repair)
by slcinwa 8/21/2023 10:00:12 AM(UTC)
Whirlpool trash compactor limit switch keeps failing (Garbage Disposer Repair)
by bhorenkamp 1/10/2013 12:18:53 PM(UTC)
Whirlpool Trash Compactor Won't Turn On (Trash Compactor Repair)
by mshamby1 4/18/2010 9:56:09 AM(UTC)
Whirlpool trash compactor (Trash Compactor Repair)
by John Wieczorek 11/11/2009 6:15:03 PM(UTC)
Whirlpool trash compactor jack hammer sound (Trash Compactor Repair)
by tdt15680 7/20/2009 8:14:15 AM(UTC)
Whirlpool Trash Compactor Power Nut Cap (Trash Compactor Repair)
by Ron Kenney 4/19/2009 2:23:09 PM(UTC)
Whirlpool Trash Compactor Stuck In Closed (Trash Compactor Repair)
by cdmue 2/23/2009 4:54:56 AM(UTC)
Whirlpool Trash Compactor Model GX900QPKB0, Banging Noise (Trash Compactor Repair)
by moscotty 9/16/2008 12:40:03 PM(UTC)
Model Tu4100xtp2 Whirlpool Trash Compactor (Trash Compactor Repair)
by Al Ojeda 2/18/2008 11:28:26 AM(UTC)
Whirlpool Trash Compactor --Model #TC900QPDQ1 (Trash Compactor Repair)
by trout 10/10/2007 1:27:21 PM(UTC)
