We bought the whirlpool duet frontloader about a year and a half ago.
For the past year this washer has given me nothing but trouble. First I will start a cycle for example normal half way through it will stop and start beeping and the lights will start flashing. It will flash the time that is left and the letters F or H or something like that and it will just keep beeping. I will cancel and restart it but it will go back to the same thing the beeping and flashing by the control panel and then the doors lock and I cant even open it.
WHen we bought it we did not realize that is had to have the HE detergent so we were using regular Tide could that also be a cause of the machine not working properly. Maybe the residue of the regular tide cause some sort of build up
I live in dearborn michigan can you recommend a repair place that is good at what they do.
Thanks Jacklin
FH sounds like a fill issue, what cycles are you using, and does it drain in drain and spin.
As far as the non HE detergent is concerned as long as you have not continued to use the non HE soap, and have run the clean washer cycles with a washer cleaner, then you should not have any lingering issues.
