I spilled water on the interior glass of my oven door and it cracked. A few small pieces of the glass have come out into the oven. Two questions:
1-- Is it necessary to replace it? Can I safely continue to use it with the broken glass? (I have been using it for many months now without any noticable problems.)
2-- I am having a difficult time finding the replacement part. Do I need to plan to replace anything else in this repair? Should I just order the glass?
Thanks for any help.
--John
Here are your parts Model JBP26WB5WW1-- Is it necessary to replace it? Yes Can I safely continue to use it with the broken glass? No 2-- I am having a difficult time finding the replacement part See above link Item 32 in the "Door" section. Do I need to plan to replace anything else in this repair? Does not look like you will need anything else Should I just order the glass? Looks like it comes as a window pack same as a dual pane house window |
THIS FORUM IS DEAD!!!!!!! |
Thanks. You said item #32 in the door section. I don't see an item 32. I see part 338 that looks like the interior door window to me. Is that the right part?
Also, how to I get the door off the oven for the repair?
Thanks for the help.
-John
You're definitely good. I'm impressed. Thanks for all the help. I wish everyone had good customer service like you folks. I'll place my order today.
Got the replacement glass from AppliancePros. Great! I got the door off the oven. The only way I see to get into the door to replace the glass seems to be by removing the star-screws from the inside panel of the door. True? I need a special screwdriver? Thanks for any help!
only way I see to get into the door to replace the glass seems to be by removing the star-screws from the inside panel of the door. True? As far as I know Yes
I need a special screwdriver? Yes They are Torx Available at hardware, auto and tool supply stores. |
Thanks again for all your help. Picked up a Torx set from the hardware store (luckily it came with some small sockets too, which it turned out I needed). Took the door off and removed all the screws from the inside panel and the bolts from the bottom and took the door apart. The glass went in without a hitch! Now with the glass looking good, the inside of the oven looks a mess. Ugh. Now I've got to clean that! :)
Thanks for the help!
