zekele
#1 Posted : Tuesday, February 17, 2009 4:09:12 PM(UTC)
zekele
My microwave failed three weeks ago, it appeared to function perfectly apart from the fact that there was no heat generated. I put a spare microwave in its place, and the second microwave (completely different model from a different manufacturer) failed in exactly the same way today. So I have two dead microwaves in the space of three weeks. Both were plugged into the same wall socket.
From reading here, it is probably the magnetron which has failed in both cases. So my question not what happened or how to fix the machines, but WHY it is happening: what possible common cause is there? The in-wall wiring is old and we've had problems with failing fuses before in our kitchen.
Can a power surge via the wall socket make a magneton fail? Or what else could it be?
Thanks for any suggestions!
TechnicianBrian
#2 Posted : Tuesday, February 17, 2009 5:22:36 PM(UTC)
TechnicianBrian
This seems like an odd coincidence, but it is possible power spikes or drops during operation could cause problems with the magnetron's. The magnetron's use the incoming voltage, steps it up and inverts it to produce the microwave energy used during the cooking process. A voltage supply over or under the specified incoming voltage will cause problems to some extent. Try and stick with a dedicated outlet for a microwave just to prevent possible undercurrent conditions as well as noise from other items on the circuit. Hope this helps.
