ihave a maytag washer by amana the spin agitation pulley attached to transmission shaft seperated .what steps do i take to install a new one.i cannot seem to be able to remove it from shaft. the base plate blocks it from coming off. the pulley is gray+plastic about 8 inches in diameter, thanks
Hi misterfixall The complete instructions you can find in the service manual for your washer. Good luck. Gene.
thank for the info, seems like alot of work to install a pulley.surely they could have come out with a simpler design.
