I have a Kenmore 665-16029401 dishwasher there are no red lights coming on. AC power is coming to the dishwasher at bottom. I verified that. The control panel was repiared under warranty several years ago. Everything was working just fine then nothing. No smell or anything just dead panel. Checked all connections and everthing looks fine.
Rick
Your M# dosent come up. The first thing I would check is the THERMAL FUSE that has 2 black wires going to it!!!! Its mounted onto the control board in the console. To test it, remove the wires from the fuse amd connect them together, If it runs, beplace the fuse!!!!!
