rvanetten
#1 Posted : Wednesday, November 7, 2007 6:24:37 AM(UTC)
rvanetten
I have gass dryer that has stopped heating. I have check the Thermal Fuse, the Thermistor, the Thermostat, the Sensor Radiant, the Gas Valve Solenoids and the Igniter with an ohm meter and they all read good. I have then tested the the heat switch and that too is okay. I don't know how to test the computer board or what else I should check. Help!
Thanks,
Rebecca
#2 Posted : Wednesday, November 7, 2007 1:08:44 PM(UTC)
Hi rvanetten
Run the test as described on the page 6 in the Test Procedure.
In your situation the problem could be a bad heater relay or a bad control board.
- The part number for the heater relay AP3037419
- The part number for the control board AP3598457
Good luck.
Help!!! Need Kenmore Dryer Repair Manual!!! (Dryer Repair)
by jonzo 10/1/2010 5:36:51 AM(UTC)
Kenmore Dryer repair (Dryer Repair)
by anniesmomrocks 2/13/2009 3:52:38 PM(UTC)
