eddye
#1 Posted : Sunday, February 8, 2009 1:26:05 PM(UTC)
eddye
My kitche Aide washing machine keeps over filling and dumping water into my utility room. Is there a solinoid valve that is the main source of this problem? If so can you tell me where it is located? Thanks for the help!!!!!
#2 Posted : Sunday, February 8, 2009 5:00:47 PM(UTC)
You need to give a Model Number
How do you stop it from filling.
If shutting it off or unplugging it stops the water then the problem is probably the water level switch or it's pressure tube.
If you have to turn off the water supply then it is probably the water inlet valve.
