bgosper
#1 Posted : Tuesday, May 24, 2011 4:54:15 PM(UTC)
bgosper
Hello,
My "Clean" light is flashing. The manual says this is a malfunction in heater circuit.
Anyone know if that means the heating element, the control panel or something else? If unsure, how to determine that? How do I test it?
Thanks...!!!!!!1
#2 Posted : Wednesday, May 25, 2011 2:09:38 AM(UTC)
Replacement parts for WHIRLPOOL DU1100XTPB6 UNDERCOUNTER DISHWASHER | AppliancePartsPros.com
Could be any of the items you listed.
First thing to try is to remove the power from the unit for 5 minutes or so to see if it will reset.
Look over the tech sheet and run any applicable tests.
If this does nothing check the heater and the hi-limit thermostat with a meter.
If OK
Check the wires from the heater/hi-limt up to the control board.
If all OK then it is likely the control board is shot.
File Attachment(s):
DU1100.pdf (168kb) downloaded 20 time(s).
