Blue
#1 Posted : Thursday, February 5, 2009 7:41:25 AM(UTC)
Blue
I have a Maytag Performa washer that makes a gear grinding noise during the wash cycle. It spins and drains fine. I replaced the agitator base and the noise is still there. What might be the problem?
tonyl
#2 Posted : Monday, March 30, 2009 6:32:21 PM(UTC)
tonyl
Hi Blue,
I have the same exact problem on my Maytag Performa! One day the noise just started, everything seems to still work - I just haver this horrible noise like a gear is stripped or something. Only makes the noise when agitator is on, you can feel the vibration of the noise via the agitator. I took the agitator off expecting to see damage to the plastic splines - but nothing, they look OK. Did you ever figure out what the problem is?:confused:
richappy
#3 Posted : Tuesday, March 31, 2009 8:38:41 AM(UTC)
richappy
You both might have a bad pump, just pull off the front panel, remove the belt and check the pump. If pump is ok, turn the trannt pulley in the agitate direction and check if you feal something binding in the tranny. If so, you need a new tranny.
Noisy washer spin (Washer Repair)
by TomHudson 10/22/2023 8:01:49 PM(UTC)
noisy washer, but difficult to pin down (Washer Repair)
by kScottk 4/16/2023 10:00:12 AM(UTC)
noisy washer (Washer Repair)
by intimidatorwrath 7/25/2016 6:11:33 PM(UTC)
by plumber123 11/3/2013 3:56:35 AM(UTC)
Noisy Washer (Washer Repair)
by Nav5805 11/9/2011 5:12:17 PM(UTC)
Noisy washer with water pump leak (Washer Repair)
by zippy617 1/23/2011 12:20:46 PM(UTC)
Noisy washer (Washer Repair)
by jerry2083 6/26/2010 2:13:19 PM(UTC)
by william clegg 1/12/2010 8:08:57 PM(UTC)
by william clegg 1/10/2010 6:53:11 AM(UTC)
very noisy washer at dryer cycle (Washer Repair)
by awalle 6/28/2009 11:15:21 AM(UTC)
very noisy washer (Washer Repair)
by Eric Nelson 6/26/2009 12:43:03 PM(UTC)
by worthless52 2/25/2009 9:34:31 PM(UTC)
Noisy washer (Dishwasher Repair)
by marsden4 6/19/2008 9:26:15 AM(UTC)
by looz98 4/4/2008 7:58:07 AM(UTC)
Noisy washer drain pump? (Washer Repair)
by mehullica 10/28/2007 10:49:41 AM(UTC)
