rschem
#1 Posted : 17 years ago
rschem
Dishwasher fills and pump seems to run but no water is moving.I checked the filter, impeller and coupler all seemto be a-1 condition.Could this be a bad capacitor?
rschem
#2 Posted : 17 years ago
rschem
I just tested cap. It seems ok. Motor is reading 27 ohms should be 3-4 on terminals j8-j5 . I now believe motor is shot.
richappy
#3 Posted : 17 years ago
richappy
It may be just your drain pump working and not the main motor. In the wash mode, I would check for current to the start winding(the red wire to motor) and current to the run winding(yellow wire)If either of these is not drawing current, you have a bad control module.
It is possible both motor and control module is bad. It is hard to test motor without a motor tester. I would just replace the control module.
philfrommaine
#4 Posted : 17 years ago
philfrommaine
I have the same model maytag MDB6650AWW. Dishwaher has power but cycle stopped cold in the middle of a drain cycle (I think - still some water in the tub). No electronic feedback to the key pad. Assuming its either the keypad itself or the control panel. Any feedback would be helpful.
Maytag dishwasher model MDB4949SKZ1 (Dishwasher Repair)
by thepontif about a year ago
Maytag dishwasher drain always runs? (Dishwasher Repair)
by Guest about a year ago
Heating element won't turn off on Maytag dishwasher (Dishwasher Repair)
by Guest 2 years ago
Maytag dishwasher not cleaning top shelf very well. (Dishwasher Repair)
Maytag dishwasher leak from bottom of door (Dishwasher Repair)
by Guest 3 years ago
Maytag dishwasher, cancel button (Dishwasher Repair)
by jtt21 3 years ago
Maytag dishwasher quiet series 300 (Dishwasher Repair)
Maytag Dishwasher Not Entering Installation Cycle (Dishwasher Repair)
by Sparky9680 3 years ago
Maytag dishwasher MDB4709AWW1 (Dishwasher Repair)
by dkmc1953 3 years ago
Maytag Dishwasher stops several times during normal cycle (Dishwasher Repair)
by vanordens3 3 years ago
Maytag Dishwasher Making Clanging Noise Even When Empty (Dishwasher Repair)
by gtg931 3 years ago
Maytag dishwasher leaking and smoking (Dishwasher Repair)
Maytag dishwasher MDB4949SDZ0 (Dishwasher Repair)
by tonygm 4 years ago
Maytag Dishwasher LEAKING underneath (Dishwasher Repair)
by bakerid2000 5 years ago
Maytag dishwasher fills, then drains (Dishwasher Repair)
by vtfireman85 6 years ago
