XtheEdgeX
#1 Posted : Wednesday, February 4, 2009 9:56:58 AM(UTC)
XtheEdgeX
I just found this site. I really like your forums. I have several Amana RCS10DA microwaves, and they all have the same symptoms. Everything works, but they will not heat. I was hoping to get a service manual here, so I can view the steps on how to check the magnetron. The manual for another model explains how to use a multimeter and check ohms on the magnetron terminals. When I check a known good and bad unit, the meter reads the same for both. Maybe the steps are different for this model? I have resorted to using a known good magnetron in the non-working ovens to verify if that is what is wrong. Hopefully a service manual will explain how to check them before removing them. Does anyone have a service manual that I can download? Thanks a lot for your help.
Amana microwave blows fuse when opening door (Microwave Repair)
by txdutchman 1/28/2018 8:18:27 PM(UTC)
Amana microwave will not heat (Microwave Repair)
by ckiley 2/1/2013 11:51:23 AM(UTC)
Amana Microwave making louder noise than normal (Microwave Repair)
by miklik 7/1/2010 8:29:52 AM(UTC)
Amana Microwave humming (Microwave Repair)
by relyons 10/16/2009 11:53:27 AM(UTC)
Amana Microwave (Microwave Repair)
by jerryo 1/10/2009 7:40:43 AM(UTC)
Amana microwave (built in) (Microwave Repair)
by lhahn 10/15/2008 5:47:14 AM(UTC)
by jtiedens 2/13/2008 7:26:34 PM(UTC)
Amana Microwave will not heat (Microwave Repair)
by heitl 1/5/2008 8:25:06 AM(UTC)
