I have noticed water around my washer and have not seen any visible signs of leaking around the supply hoses or even the drain hoses. I suspect there maybe something leaking from inside the machine. Where should I begin?
Originally Posted by: mdelo ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) I have noticed water around my washer and have not seen any visible signs of leaking around the supply hoses or even the drain hoses. I suspect there maybe something leaking from inside the machine. Where should I begin? Mdelo, You'll need to remove the front panel of the washer, Open, the door, remove the 4 screws and 2 retainers holding the door to the panel, lift up slightly on the door panel and remove the door. Twist out on the smaller upright area of the panel, and pull out until the retainer clips disengage, then lift up on the panel to disengage it from the lower panel clips. you then can reinstall the door(no screws necessary) and start and run a cycle, so you can observe the leak. You can also move the washer out, far enough to get behind it,remove the louvred rear panel in the plastic frame, and observe the rear components for a leak as well. :) :) :)
