oldrugrat
#1 Posted : Sunday, May 15, 2011 3:59:51 PM(UTC)
oldrugrat
the dryer quit heating and about a week later the washer will not work at all. It was working great at the old place, we moved into the new place and had to put in a double pole 30 amp and run new wire, I used a 10/3 wire.
#2 Posted : Monday, May 16, 2011 5:26:48 AM(UTC)
Replacement parts for WHIRLPOOL LTE5243DQ3 LAUNDRY CENTER | AppliancePartsPros.com
Since you used 10/3 I am assuming this unit is a 4 wire hook up and that the old house also used a 4 wire hook up.
Is this correct or is it something else?
The first thing I would check is the power to the unit.
L1 to L2 should be 240 volts
Neutral to ground should be 0 ohms.
If OK
If OK
[COLOR="Red"]Be careful as 240 volts is lethal !!! [/COLOR]
File Attachment(s):
LTE243.pdf (276kb) downloaded 1 time(s).
oldrugrat
#3 Posted : Monday, May 16, 2011 4:22:10 PM(UTC)
oldrugrat
thanks so much, your advice wasnt what was wrong but it sent me on the right track. The breaker that I had installed was only hitting on one pole so I was just getting half of the amps needed. thanks again, I dont think I would have gotten it without your help.
#4 Posted : Tuesday, May 17, 2011 4:00:53 AM(UTC)
You are welcome
