Maze
#1 Posted : Saturday, January 24, 2009 5:04:37 AM(UTC)
Maze
My dryer has a push knob switch and the other day I pushed the knob in to turn it on and it would not start. The light on the iinside of the dryer is still working, so I knows it's getting some power.
#2 Posted : Saturday, January 24, 2009 7:14:16 PM(UTC)
Did it make any noise? Did you check the circuit breakers for the dryer?
The model number you posted does not come up. Verify and repost it.
kayakcrzy
#3 Posted : Sunday, January 25, 2009 4:54:11 AM(UTC)
kayakcrzy
the model came up with no problem for me!! it is most likely the thermal fuse kit. the part# is la-1053. it is located on the right side if the element housing. just follow the 2 white wires. tom [url=]applianceeducator.com - parts[/url]
#4 Posted : Monday, January 26, 2009 6:14:32 AM(UTC)
Here is your parts breakdown includes wiring diagrams
Model Search
Note the wire on the right side of the MOTOR CENTrifugal Switch goes to L2.
It is just cut off on the diagram.
Your circuit path to start the motor is NEUTRAL , THERMAL FUSE , DOOR SWITCH C/NO , MOTOR's Run and AUX windings , MOMENTARY PUSH TO START switch , TIMER contacts M/L , L1
Fuse should be OK because the light works. This does not mean that the door contacts close when the door closes. Try manually closing it. Note also could be the contacts in the switch may be blown.
I would unplug the unit and use a meter to check the components.
If you do not have one I would suggest you purchase one. You can get a decent digital multimeter for under $20.00. You do not need fancy though it is nice if the leads are a couple feet long.
kayakcrzy
#5 Posted : Tuesday, January 27, 2009 10:35:28 AM(UTC)
kayakcrzy
Denman, do you find it odd, how on this site people don't get back to us, like they did on the Parts Select site. Tom
#6 Posted : Tuesday, January 27, 2009 1:47:31 PM(UTC)
Yes some what but do get some replies and even the odd thank you.
If I had noticed that your post was back on the 25th I probably would not have bothered with this one, if it is a couple days old, it is most likely dead.
kayakcrzy
#7 Posted : Wednesday, January 28, 2009 4:59:16 AM(UTC)
kayakcrzy
Thanks for the reply Denman. Tom
Cycles stop working intermittently (Washer Repair)
by sgaissert 5/23/2023 2:10:32 PM(UTC)
Maytag Gemini-ovens randomly stop working power interrupt error (Oven Repair (including Ranges and Cooktops))
by romdos 9/2/2018 5:11:08 PM(UTC)
Refrig/Freezer stop working suddenly (Refrigerator & Freezer Repair)
by japthorpe 7/8/2015 10:31:57 AM(UTC)
GE fridge compressor and water dispenser stop working at same time (Refrigerator & Freezer Repair)
by silver02ls1 4/27/2015 6:34:02 AM(UTC)
Intake drain dishwasher no stop working (Dishwasher Repair)
by Giu62 3/11/2015 10:34:05 AM(UTC)
Intermittant Issue -- Icemaker and Water / Icemaker Dispenser stop working (Refrigerator & Freezer Repair)
by GoVikings1 12/31/2014 2:33:47 PM(UTC)
Haier ice maker hot to touch, gears stop working (Refrigerator & Freezer Repair)
by Darlene Coleman 7/9/2014 10:28:55 AM(UTC)
Refriderator stop working (Refrigerator & Freezer Repair)
by Yuan 3/30/2014 11:46:57 AM(UTC)
Hotpoint Refrigerator & Freezer stop working (Refrigerator & Freezer Repair)
by Sam2628 4/27/2013 8:17:47 AM(UTC)
All Gas stove Ignitors stop working (Oven Repair (including Ranges and Cooktops))
by weeties61 3/21/2013 7:16:07 AM(UTC)
dryer stop working (Dryer Repair)
by howardr57 2/18/2013 10:08:28 AM(UTC)
Stop working at middle-circle (Washer Repair)
Belarus langkhach2013 2/18/2013 8:06:09 AM(UTC)
GE Refrigerator just stop working (Refrigerator & Freezer Repair)
by garfish 10/21/2012 12:01:03 AM(UTC)
Fridge/freezer fans stop working (Refrigerator & Freezer Repair)
by peeples 9/4/2012 9:33:21 AM(UTC)
dryer doesn't stop working w/ door closed ( timer is bad ? ) (Dryer Repair)
by jose julio alves 6/12/2012 8:14:21 PM(UTC)
