kc.58
#1 Posted : Tuesday, October 30, 2007 3:51:05 PM(UTC)
kc.58
It seems simple, but when I get the belt looped around it seems way too big. But I measured it to the the other belt and its the same. Appreciate any help. Thanks.
richappy
#2 Posted : Wednesday, October 31, 2007 2:46:19 AM(UTC)
richappy
Make sure the belt ridged side is against the drum. Then there is only one way belt will go on right. The belt should form an S shape when put on right. Loop it around and under idler pulley and around the motor pulley.
