bea
#1 Posted : Thursday, January 22, 2009 6:02:37 AM(UTC)
bea
I have 2 questions. On my maytag model mzd2766gew. I have a problem with the freezer opening when I close the frig. What could that be about. And the outside dispenser needs replacing. the key pad is breaking and rusting. Can i replace just those parts.
#2 Posted : Thursday, January 22, 2009 7:55:26 AM(UTC)
You have been a member since:: 2/29/2008(UTC)
Here is your parts breakdown
Model MZD2766GEW
See section 6 "Freezer outer door"
Here is a service manual
http://www.servicematters.com/m...ibrary/docs/16010154.pdf
You may want to check the doors bottom hinge. There is a plastic cam assembly here. Perhaps it is worn or damaged.
Also check the level of the fridge.
Make sure side to side is level
Front to back. Does not hurt to have it tilt slightly to the back.
Also sometimes and indicator that the freezer drain is partially plugged.
KitchenAid freezer door stuck (Refrigerator & Freezer Repair)
by willeaton 4/18/2024 7:31:34 AM(UTC)
Removal of French Freezer door on Frigidaire Gallery (Refrigerator & Freezer Repair)
by Guest 5/24/2023 6:11:33 PM(UTC)
Refrigerator and Freezer Doors (Refrigerator & Freezer Repair)
by AeroncaChief 11/5/2022 4:40:11 PM(UTC)
GE Side-by-Side freezer door dispenser leaking (ESS25LRBSS) (Refrigerator & Freezer Repair)
by dhunsing 9/28/2022 12:59:56 PM(UTC)
KBUDT4270A/02 SXS freezer door gasket (Refrigerator & Freezer Repair)
by metropical 3/19/2022 9:56:33 AM(UTC)
Refrigerator and freezer door lights reversed - KitchenAid KSCS25FJSS (Refrigerator & Freezer Repair)
by blacter 3/17/2022 3:50:11 PM(UTC)
Freezer door/drawer not closing (Refrigerator & Freezer Repair)
by mwarney 9/6/2021 2:14:57 AM(UTC)
How to disassemble the freezer door (Refrigerator & Freezer Repair)
by cparke 8/31/2021 7:38:14 PM(UTC)
Broken Freezer Door Handle (Refrigerator & Freezer Repair)
by Guest 8/9/2021 11:02:12 AM(UTC)
Frigidaire Freezer Door Pops When Opening - FFHB2750TS / Effortless Glide / Under French Doors (Refrigerator & Freezer Repair)
by daved31415 1/23/2021 12:44:44 PM(UTC)
Replace water line in freezer door of GE GSF25IGXNBB (Refrigerator & Freezer Repair)
by splinke 11/24/2020 3:08:26 PM(UTC)
Freezer door opens fridge door every time (Refrigerator & Freezer Repair)
by coyote2 4/9/2020 11:14:31 AM(UTC)
Ice dispenses when freezer door closes (Refrigerator & Freezer Repair)
by wrb 5/4/2019 8:08:13 AM(UTC)
Fridge and Freezer door sag (Refrigerator & Freezer Repair)
by WLHuard 7/11/2018 11:56:20 AM(UTC)
Bottom of freezer door sticks out (Refrigerator & Freezer Repair)
by smithd441@gmail.com 6/12/2017 9:23:24 AM(UTC)
