brhorton
#1 Posted : Monday, April 25, 2011 6:09:32 PM(UTC)
brhorton
This last week our freezer started warming up from 0 -24 We had seen some frost on the inside so we cleaned it out and restarted it. It still doesn't get down where it should be. We have never had any problem w/ this unit before.
Thank you for your help
#2 Posted : Tuesday, April 26, 2011 3:09:11 AM(UTC)
I cannot find any info using your model number.
What type of freezer is this?
Also I do not understand the following
"This last week our freezer started warming up from 0 -24"
Was it at 0 degrees F and is now at 24 degrees F?
Is the compressor cycling on/off?
If it is always on and the unit is not getting down to 0 to 5 degrees F, then you probably you have a problem in the sealed system.
Could be a plugged orifice, bad compressor, low on freon or out of freon.
All of these will be an expensive repair and it usually makes more sense to invest those dollars into a new unit.
brhorton
#3 Posted : Tuesday, April 26, 2011 8:49:04 AM(UTC)
brhorton
It was always at 0 is now runs at about 24 the compressor is not working as far as I can tell. United is the name of the unit.
#4 Posted : Tuesday, April 26, 2011 10:40:24 AM(UTC)
Still could not find any info on it though it looks like some United units are made by W C Wood.
Since the compressor is not running I would start at the control thermostat.
Perhaps the following will help.
Appliance Repair Guide: How To Fix a Refrigerator - ACME HOW TO.com
Fridge and freezer stopped cooling (Refrigerator & Freezer Repair)
by revg 8/12/2016 11:34:53 AM(UTC)
GE refridgerator & Freezer stopped Cooling (Refrigerator & Freezer Repair)
by kcroto 5/31/2012 1:21:23 PM(UTC)
Fridge & Freezer stopped cooling.. (Refrigerator & Freezer Repair)
by kdupreez 4/4/2012 10:18:54 AM(UTC)
Refrigerator and freezer stopped cooling (Refrigerator & Freezer Repair)
by Kathy806 2/27/2012 7:04:20 AM(UTC)
Fridge/Freezer stopped cooling (Refrigerator & Freezer Repair)
by tigergrad97 12/14/2010 3:41:07 PM(UTC)
Fridge and freezer stopped cooling suddenly (Refrigerator & Freezer Repair)
by thechristys 11/5/2010 10:47:47 AM(UTC)
1 week old fridge-freezer stopped cooling! (Refrigerator & Freezer Repair)
by jp275 1/5/2009 8:05:41 PM(UTC)
