russell
#1 Posted : Saturday, October 27, 2007 12:06:51 PM(UTC)
russell
Washing a heavy load of rugs, machine stopped agitating and spinning. Continued to fill and drain - just not clean very good or spin dry.
Replaced motor coupling - tub side broken in half.
Machine would fill. Timer made a grinding noise and would not progress - move manually - still no agitation or tub movement.
Replaced timer. Works smooth to fill - no agitation or tub movement
Removed cabinet went all the way back to motor coupling - checked all connections and confirmed position of coupling and ability to turn shaft by hand on both tub and pump side.
Replaced cabinet - start cycle - machine fill - cut off and hear an attempt to engage (visual confirmation of agitator attempt to engage - never make a rotation).
Attempt to turn bottom half of agitator seemed to bind. Pressure freeded up agitator.
There is a clicking sound of what appears to be the motor attempting to engage. Visual confirmation of agitator appearing to bind and not make a rotation.
What do I do now?
russell
#2 Posted : Saturday, October 27, 2007 12:55:34 PM(UTC)
russell
New twist - bailed tub out - pushed machine back into closet - 10-12" circle of oil/grease deposited below washer!!
Time to go for new washer?
fixxit
#3 Posted : Saturday, October 27, 2007 1:38:52 PM(UTC)
fixxit
or replace gearcase. Part # AP3096209
