had the hot water heater question can someone plz help
Give a complete description of the problem.
Nat
k heater (electric) was replaced because it leaked the one i replaced it with was one i had around for a while. prob is i hooked up and not working. multi meter read 114v on top element 0 on bottom ellement woundering also i have black n red wire from my tank and white and black from power box im lost can u plz help?
What's the voltage from the black & white wires? It should be right at 220-240 Volts.
if i put probe on each end it reads 228 volts more i think about it im thinking it is probably the thermostat unit ??? i dont want any more cold showers lol. is there a way to test thermostat can i email u?
Feel free to email me if you like.
Put your meter in continuity or ohms ( U Inverted ) and when the meter leads are separeted reading must be Infinity or open line (OL) or zero. CHeck your Heater element , must give you a number, but no (OL), that will mean the element may be ok, check the termostat it must have two wires put the meter leads one in each wire ...must give you a # , but not (OL) if it fail move the setting all the way to max . temp. check again . also it must have a limit control 2 Wires ...do the same one meter lead to each wire , that is the trouble shoot for a failed part. the one that is open is the one that is not allowing power to pass .good luck.......some limits are manual reset and have a small push bottom.that closes the swich and allow the power to continue its path.
see how to check continuity in other posts....each part that need to be checked ...need to isolated....
