My dryer wont shut off when I open the door. My thought is that its the switch in the door and should be a easy at home fix. Can someone point me in the right direction and help me in finding the part? Thank your for your time in advance.
Pull the lint screen out and take out the two screws under the lint sceen door.
Then insert a screw driver in the gap between the top and the front at the edges to flip up the top, which will flip up on hinges. You can now access the door switch. Disconnect the wiring and test for continuity with the door open. If you have it, replace the switch.
