juan2011
#1 Posted : Monday, April 11, 2011 10:26:50 AM(UTC)
juan2011
I have 120volts to the mother board.
richappy
#2 Posted : Tuesday, April 12, 2011 2:56:47 AM(UTC)
richappy
Pull out the motherboard and check for bad solder joints by the big power relay, if ok, check the resistance of the evaporator thermistor, should be around 5Kohm at room temperature, if ok, change the motherboard AP4436216
